Hello,
I hope you are well.
I don't know if I should make a presentation but here it is:
My name is gabriel, I'm from Switzerland, and I'm glad I bought a surron 6 months ago. Already 6000km, what a pleasure, especially in my region where there are a lot of people in the forest.
However, it's been several days that I'm stuck. My surron doesn't do anything anymore. No power, headlights, usb, accelerator, everything
I discovered the wonderful procedure on this site, made by someone from luna cycle I think, and I thank them by the way. But I still haven't solved the problem.
On the battery, I can only get a negative number on the voltmeter, no matter the configuration. All the cables are correctly attached (even the small pins following the tutorial), the controller does not seem to be the cause (bypass following the procedure, it does not change anything). Even stranger, when I put the battery to charge (on the surron), I hear a kind of "plok". Once, while charging the battery, the rear light was on. All the sensors were removed (brakes etc..).
I also checked the ignition, it doesn't change anything when bypassing. The white box gives me strange results too...
I'm not sure if it helps but, my surron doesn't work anymore since a session in a terrain with a lot of snow (water) and it's during a little jump, I have broken the front brake cable too, that the surron doesn't work anymore.
I get to a point where I think it's the battery? Is there any way to confirm this? Do you have any other leads?
Tanks for the help,
Gabriel
Tanks for the help,
Gabriel
