This has likely been discussed earlier, but I cannot yet find a clear answer. I have been building a bike. It has a Bafang Ultra motor. I have recently gotten to the point of hooking up the electrics and testing out the operation. So far, the motor and bike seem to operate well enough. But I have not been able to successfully connect the brake sensors yet. The brakes I have installed are Tektro HD-E725 hydraulic. The levers come with integrated brake sensors which are wired to red 2-pin connectors. Obviously, there is the immediate problem that the Bafang wire harness has 3-pin yellow/orange connectors, not red 2-pin. I have already tried just connecting the blue and black wires in the Bafang cable (disregarding the red wire altogether) to the red and black wires coming from the Tektro sensor, but this produced no result when the brake lever was squeezed. Is there some fundamental incompatibility between the Tektro sensor and the signal needed to activate the Ultra brake cutoff? Or should I try connecting other wires? Or, is there some other issue I have overlooked?
I expect I could make the brake cutoffs work by disregarding the built-in Tektro sensors altogether, and simply adhering the independent Bafang sensors and magnets to the brake levers; they are already wired with 3-pin connectors. But I would prefer to have the built-in Tektro sensors function, if possible and especially if there is a straightforward solution.
Can someone with experience offer help with this issue? Thanks.
