Speed sensor issue
    Speed sensor issue
    Bbshd kit 52 volt battery, luna kit,
    speed doesent read on dash, sensor wont flash red when magnet passes it, clearance is right, tried new sensor ,no change, bike works, but no reading the speed, what could the problem be,
    dash not programmed properly maybe?
    Hi Ken,
    No red light is obviously problematic. The sensor has three wires to it. 5vdc, ground, and speed sensor signal. Do you have 5vdc present at the sensor connector with system powered up?
    No?
    Check for defective cable between motor and connector.
    Yes?
    Try different magnet position relative to the senor. Or try reversing magnet end to end.
    Wow, just saw a great post by Sebz at the end of this thread... Give it all a read!
    https://electricbike.com/forum/forum...x-speed-sensor
    Regards,
    T.C.
