When the ambient temperature is below 70 it is difficult to overheat the motor. Putting 500 watts into motor for twenty miles barely gets motor to 120 degrees. Now at 95 the same ride temperature approaches 160. This is not good.
any body try cooling with mist, felt pad, evaporative cooling? Water bottle. Pressurized with mister in front of motor green scrub pad for water retention, evaporation??? Other than that a copper heat dissipation fin wrapped around motor...
Otherwise my 750 watt motor becomes a nominal 300 watt motor. Or new plastic gear.
