I have over 4,000 miles on various BBS01/02’s. Today I hopped on my eCruiser to hit the bike shop Black Friday sales and after braking down a freeway overpass the electric assist didn’t kick back on. My first thought was that one of the brake cutoff sensors had stuck cutting the power, so I disconnected both of them. That didn’t work, so I powered the system off and on. No luck with that either. Finally I disconnected the throttle wire just as a precaution and still no power assist.
After pedaling for a while without power and thinking through what else it could be, I stopped and checked for the light on the magnetic sensor at the rear wheel. The light was on, so I cleaned the magnet surfaces thinking maybe it wasn’t getting a proper signal. No luck once again. After that I simply completed my ride without power.
Back at home I swapped out the color display with one from another bike and nothing. Now I’m thinking it must be internal to the motor.
PROBLEM:
No power assist ever kicks on. Only unusual thing I noticed is an odd drag coming from motor when the bike is moved backwards with power on or off. It is a tugging feeling from spinning the motor backwards that I never noticed before, but could have been there (?).
STATUS AND CHECKS SO FAR:
Battery has power
Display powers on fine
Rear wheel senor is clean, aligned and the red light is on
Displays proper speed when pedaling with power on
No assist even with brake sensor cutoffs discounted
No assist even with throttle unplugged
No change with different working color display
Anyone have an idea what it could be or what to check next? Is this similar to any problems that have already come up?
ADDED 11-30-2017:
- - - SWAPPING IN A GOOD CONTROLLER CONFIRMED THE CONTROLLER WAS BAD - - -
PROBLEM:
Battery has power
ADDED 11-30-2017:
