I recently got a charger from Luna cycles and has been working fine for the 2 months I've had it until I tried charging it today and both lights keep flashing and it doesn't charge now. Wonder is anyone else has had that issue. I checked the fuse and nothing's blown.
52v 3amp charger not charging
Originally posted by paxtana View PostFor some reason the factory set it so it trickle charges when pack voltage is fairly low. We have an adapter that plugs into the end of it that stops it from doing that. If you want to send me your order number I can have it sent out.
Not charging fast if pack is real low is probably prudent and conservative, from a charger design standpoint. Understandable choice by a manufacturer, then, even if not a universal one.
Good to see the issue resolved. The service is really good and you guys are awesome to say the least. Cheers
https://validedge.com/plugged-in-not-charging/Last edited by nolanchrist007; 09-25-2019, 11:46 PM.
