Throttle without pedaling first
    I talked to the supplier they said they had this built into the programmer because they didn't want people accidentally hitting the throttle before they were riding I bought the Luna Black Box thinking I could turn this off or reprogram. the black box works I can change all of the settings but I don't see where I can change this setting so I have throttle without pedaling first just to be clear the throttle does work without pedaling if the bike is already moving but when you first get on the bike before you start riding or pedaling the throttle does not work.
    Hi Mike. At the end of the day, it's still a push bike. Plenty of advantages pedalling to get rolling as opposed to just tickling the throttle, if you can.
    • Mike
      Mike commented
      Thanks for the response my son has a lower voltage same
      brand bike his throttle works from a stop it's just nice to have it when you're in a difficult situation like deep snow and you came to a complete stop where it is tough to get that first full pedal, in order for the throttle to work like I said I talked to the people who sell these bikes they said they had it programmed in for safety so there has to be some way to program it out
    Have you seen theses articles? Maybe his settings will do what you want. If you're describing the BBS02 or BBSHD, Luna sells them programmed for the throttle to always work.
    https://electricbike-blog.com/2015/0...g-your-sanity/
    https://electricbike-blog.com/2015/0...ing-the-bbs02/
      You can program the controller to enable throttle without pedalling at whatever power you want and at PAS 0 if you want. See links on how to do that provided by the post above.
