Build an ebike but rear brake caliper is touching the motor pls help
    Hi
    i just build an ebike with a 1000w rear hub motor
    Battery is Samsung 48v 16 ah
    I am facing an issue
    I placed a washer between the frame and disc brake but then too the rear capiler is touching the motor and am unable to tighten the bolts
    Pls help
    It's a. Shimano m355 160 mm disc
    Should I change it to 203 mm or 180 mm
    Or should I turn to normal brakes
    It's a hydraulic brake system
    Pic for referrence
