Finally got my cyclone build together and in the testing phase. Thankfully everything was aligned properly first go around with no real issues. When riding, there is an extremely small sweet spot where the throttle will gradually increase the torque. Anything under that won't give any power at all and anything above that will give quite a jerky start. Also, it seems when I slightly overturn the throttle (especially to go up hills and things) it just kills the bike entirely. I can unhook the battery from the Cyclone, plug it back in, and everything will work again albeit with the same problems. Also, I'm dumb and don't know how to program my controller different from factory settings. Would that help? I'm getting voltage readouts in the mid 60s on my throttle.
Specs:
60V 24ah Battery
Cyclone 3000
40amp 48-72V Controller
Full grip Twist Throttle (I just noticed this is for 48V only so the voltage readout might be off.)
Specs:
60V 24ah Battery
Cyclone 3000
