Can I test my dpc-18 display some how?
    I would like to get my bike running again, but I cannot get the display to turn on. The battery is charged, and the motor is new and hasn't been tampered with. The motor won't start because the display won't work. Any ideas?
    Have you verified the motor won't start because of the display, like using a programming cable? Or are you just assuming? If you're just assuming, you might wanna check your battery connection. What kind of battery are you using? Did you measure it's voltage to see if it's outputting the correct amount?
