Bafang rear hub kit throttle problem
    I have 188 KM on the Bafang rear hub motor, and the throttle just quit, the DCP-18 display works and there are no error codes. No throttle response at all, everything was fine on the last ride I charged the 48v 20 ah triangle battery pack and the display shows %100. The throttle is a Luna right twist. It does not look like Luna even carries the Bafang Hub kit at this time. Any help would be welcomed.I have the battery off the bike at the moment and am checking wiring and connectors etc.
    Probably either throttle, connectors, a kinked/crushed/cut harness or the controller is fried. Check wiring and connectors then throw a couple parts at it
