Good day everyone!
I'm having a problem with my e-bike builds mechanical power train. Here are the details.
In the highest gear, smallest sprocket, furthest away from the Magic Pie 5 hub motor. And under moderate to strong peddle input I will get what is best described as a "POP" and a quick 10 degree slippage down. Some times twice in quick succession. It happens on either leg driving the force. It seems to me that its coming from the rear freewheel/derailleur. But impossible for me to spot. No problems in any other gear. It's a 7 gear Shimano threaded on freewheel. Single chain ring in front. Twist shifter.
Efforts to fix...
Derailleur hanger alignment. Parallel with the freewheel gears.
Derailleur adjustment, low, high, linear tracking.
Removal and disassembly of the freewheel hub assembly. Checking of the pawls, ratchets, shimming and general operation and relube. A slight touch of marine grade grease, and 20 weight non-detergent oil.
Maximum/minimum derailleur gear positions...outside of recommendations.
I can get everything to work smooth as silk, with perfect alignment, and shifting top to bottom. But the minute I put a bit of power into the downstroke...POP. Arrrggggg.
In the interest of full disclosure, I seemed to have made it worse after the hub teardown and re-lube...
Pictures of the terror...
Inside of the freewheel hub...
Any help would be greatly appreciated!
Best regards,
T.C.
Efforts to fix...
Best regards,
T.C.
