Battery bypass
    Battery bypass
    Can you hook up a 12v trickle charger to the leads off the motor to by pass the battery to see if it will light the display?
    Probably not, unless it is a 12v nominal controller.
    You can use the battery charger to do this though. There's a video in the troubleshooting section
