Cyclone 3K - No Output Power
    Battery is at 82V according to my throttle display. I'm not sure how to troubleshoot output from the controller to the motor. There's one yellow and green connector, one single blue wire connector and one 7 wire connector from the controller. (There are two wires in the 7 wire connector labeled, "Hal I sensor" and "Power Switch") How can I determine if the issue is with the controller or the motor? Thanks in advance.
    Last edited by Eastcreek; 07-15-2018, 09:47 AM. Reason: Please disregard. My E-Brake sensor came loose and was no longer making magnetic contact with the magnet I have mounted. Duh!
