Hi bought the above for a fat bike build after reading good reviews of the Luna lander fork, I received the fork surprisingly pretty quickly, however when I installed the fork I found it to be rather sticky,
Ok its a new new fork so will need to give it time to bed in, however to be perfectly honest i am really disappointed in the performance of the fork, instead of getting better it has got worse,
the damper adjustments are poor on slow setting and fast setting is worse, when the fork compresses it will not return, it is that bad with stiction it feels like it is locked out
I rode same bit of trail last night and got one of my friends to ride it and he felt that it was locked out as well.
I have experimented with various settings from 30 psi to 60 psi and I weigh 14.7 stone (205lbs) still the same,
I have even let all the air out and repressurised and still no difference, as the forks are under warranty I do not want to start stripping them down ( I never received any instructions with the fork re recommended weights etc. only a plastic bit of pipe)
any advice would be appreciated, the only thing that is working fine is the lock out
thanks
G
thanks
G
