Cyclone mid drive 3000 watt throttle cutting out
    Hi,
    I just installed the cyclone 3000 kit on my first e bike it all went well,the only thing is when i let off the thumb throttle and then get back on the throttle
    the motor don,t turn back on in till i re-throttle a few times. I thank its the hall sender or the speed controller ?
    thanks mitch
    could be unbalanced battery causing bms to cut off the battery due to higher load.
    That happened to me my 1-2nd week after the initial balance that i did to the battery. After i balanced it, it worked perfectly fine.
    • mitchmade
      mitchmade commented
      I got it going, it was the Thumb Throttle.
      Thanks for the other pointers.
      mitch
