BBSHD crank dragging when rotated backwards.
    Stripped BBSHD with 300KM on clock and found the following. Oil seal on left side was 25mm OD housing is in fact 26mm OD . Damage from water ingress means a new crankshaft and needle bearing plus the correct seal.Don't get me wrong I love this product just check your oil seal on the left side as you assemble your Ebike conversion kit.
