So I used my ebike consistently for 9 months or so, then I didn't use it for 3 months. Now it is doing something strange. It works fine for up to 4-5 miles but then it just cuts out, full power off as if the battery were clicked off. If I click the battery on/off and reboot, it works again for a few minutes. Then if I do it again, it works for a few seconds. Then it just doesn't work. I've checked all the wiring on the battery and it doesn't seem to be the problem. I removed the brake cut off cables and disconnected the pedal power clips. Nothing looks wrong leading in/out of the controller. I opened up the throttle case and everything looks OK visually. No corrosion, loose wires etc. I just ran a test to make it happen and it did. The battery is still showing 39v (36v nameplate). No clue what this could be. The only thing I haven't opened up is the control box itself and the motor.
Could something be over-heating? Has anyone else had this problem?
It's a cheapo ANCHEER from China but it was working just fine and now it's not. Any guidance would be greatly appreciated as it is my first e-bike.
Thanks!!
Thanks!!
