Battery Sparking and Blown Fuses
    Hello All!!!
    I recently built an electric bike (or at least in the process of) and I am having some trouble when completing the circuit.
    I purchased a hub motor from amazon rated for 1000w and it needs 48V to run. I have four 12v SLA batteries (in retrospect, not the brightest due to weight but was on a budget when I was buying parts).
    The hub motor comes with a motor controller and a fuse on the connecting line (I will have to find what fuse size later on today and will update) which is set up with your standard 3-prong plug like you would find in most electronics as well as an on/off switch on the throttle.
    What I was doing before was connecting all four of my batteries in series and then plugging in the 3-prong connector. I would notice I would hear a small spark, but so long as I made the connection quick and smooth, everything would work out just fine. I once attempted to plug in the 3-prong connector and didn't manage to seat the plugs right away and heard a more considerable spark than previously and I blew my fuse out and also corroded my connection beyond repair.
    I clipped the connectors and simply spliced the wires together, but now every time I go to complete the connection on my batteries I see a large spark and my fuse blows every time.
    Does anyone know how I can prevent this arcing when I complete my connection? I am pretty desperate to get this thing running since I have been working on it for quite a while and haven't gotten it to the point where I consider it a 'working e bike'. I've read a few posts regarding adding a resistor and some others showing people have used an on/off switch as their solution (but my controller already has a push-button on/off).
    Thanks!!!
    EDIT: Corrected from XT60 to XT90
    There is a 2 pin connector called XT-90AS, anti-spark. Luna had them last time I needed some.....still do, I bet.
    It has a pre-charge resistor in it, so if you plug in slowly, that resistor completes the circuit first, limiting inrush current. But, that can't carry enough current for riding, so there is a 2nd stage, without the resistor. All built into the pins design of the connector. Try one of those on your battery connection.
    If your motor/controller kit is damaged/shorted, it won't help, but if it is functional and this is just inrush current, it will help. Again, it connects in 2 stages, go slowly when inserting the connector, to give it time to pre-charge.
    Good luck!
      Thank you so much for your help! So I went looking around on Lunacycle for an XT-60AS but I was only able to find an XT-90 Anti Spark plug kit. From what I can tell, the only difference is the rating of the plug that is being used, so paying a little bit extra for the 90 doesn't bother me at all. It also looks like this part incorporates the pre-charging circuit that I have been seeing so much about, so this looks very promising!
      So from what it looks like I should be able to simply splice/solder this connector into my pos/neg lines between the battery and the motor controller and I'm good to go, right?
      I am going to order some of these and install and I'll post again with updates!
      Again, thank you so much for your insight, this is a huge help! I know my bike can use a few improvements in some other areas, so when I get everything up and running hopefully I can post with a few pictures and details and see what the community thinks!
      • JPLabs
        JPLabs commented
        Good! I meant XT90, actually, you got the right ones. Post above has been corrected, thanks for pointing that out.
      JPLabs,
      XT90 plugs arrived about a week or so ago and I have installed them and have since ridden my bike without problems. THANK YOU SO SO MUCH!!! I cannot tell you how relieved I am to know that this was such a simple fix and that my bike is up and running. Rode to work and back the other day and it seemed like I was able to hit a decent speed (a bike app clocked around 27mph and didn't manage to hit full speed, but I take that with a grain of salt). The bike works great!!!
      Now I can focus on making the design more robust, next step is to figure out a more sturdy mount for my 4 12v 22ah (each) SLA batteries.... (man I wish I had waited and bought LiPo....)
      I still might get a Lithium battery in the near future, but they all seem quite expensive and I am worried that 12 or so amp hours won't be very much (even though that is what I am seeing on most e-bikes).
      Thank you again!!!
        Great! This example shows that, even if the answer is not crystal clear, trying the "best guess" is worth a try.
        Thanks for reporting back with your success in fixing your bike. Feels great, eh?
