BiXPower battery not discharging
    I have a BiXPower 36V 11.6Ah battery powering an 8Fun 350W front hub motor. I was riding recently when the battery ran low and gave out. But even after recharging the battery doesn't discharge - the light meter indicates a full charge, but the little red LED on the switch doesn't go on when switched on and no power flows. Is there a way to reset it reactivate the battery?
    Hi viajegancho,
    And welcome to the forum!
    After first checking your fuse, this thread will show you how to do a jump-start and hard re-set of the BMS. As well as some other helpful information.
    http://electricbike.com/forum/forum/...ctrical-issues
    That's quite a compact battery!
    Regards,
    T.C.
