Please help explain what this noise is coming from ?
    You may need to put the volume on high.
    I filmed it in a noisy spot so its faint on the video but quite loud in person. It makes that squeaking noise when the wheel slows down.
    The first thing I would look at is the brake rotor. On the old BB7 you could back the pads out. IDK about hydros though. I've also had that from the caliper housing itself touching the rotor. If the rotor isn't straight you can carefully tweak it back with a crescent wrench.
      Retrorockit Thanks for writing. We took the brake rotor off. We did it to make sure it was nothing to do with the brakes. So we are still stumped to what it may be.
