I Hi guys
I recently got a used scooter, and the seller claims to know nothing about it. I outlined the issues here:
https://www.youtube.com/watch?v=XwZE...ature=youtu.be
(basically wheel locks when given throttle, charger freeks out when plugged into charge port).
In addition, I followed the hall sensor test here:
https://www.youtube.com/watch?v=Y4O9YQG08vE&app=desktop
Following this procedure, the green Hall sensor wire clearly has a problem. It never drops below 4.25 V (from 5v). The other 2 wires start at 5 V, and oscilate to 0v.
If this is indeed the problem, I believe I can just replace the Hal sensor in the hub. I want to confirm that the issue is in the hub - not the corresponding part in the controller? Are all hall sensors for these hub motors the same, or brand specific? I’ve ordered these:
10PCS SS41 SS41F TO3 SENSOR SS HALL EFFECT BIPOLAR NEW GOOD QUALITY
https://s.click.aliexpress.com/e/cplgJdXE
Still not sure why the battery charger will not charge the battery. Is there a test I can perform on the charger or battery before having to take the battery apart? If I must take the battery apart, is there a guide on how to test the BMS and the rest of the battery properly without destroying it?
I also assume none of these issues could be caused by the throttle?
Anyways, thanks again so much for your help guys!
