Ya, the hall seems to ‘drain’ voltage after throttle release. Drops most of course from 3.62v, but there is a small but long gradual drop to the 1mv. Not like it’s a clean drop to 1mv. Not sure if that makes sense.
Ill try to get 2 more hands to help me.
Have not tested from hall negative, but previous test useing board negative showed no voltage change at all until over half way throttle. I’m going to assume it’s the same useing hall negative. Would this happen with your suspect of low starting voltage? I mean it seems nothing at all is going in, low or otherwise, when you pull the throttle until half way .
