Got a short when mounting battery in rain. What is likely to be wrong?
    I have a Luna kit with BBSHD Bafang motor. It was very wet when I mounted the battery and I heard a pop where the battery connects and now it doesn't work. How do I go about fixing it.
    I have tried connecting the battery to the charger so it may unfortunately be some low power tap on the battery sent the full voltage to something that couldn't handle it.
    Look for a fuse on the battery. If the connections were wet when you connected the battery they may have shorted and blown the battery fuse. Somewhere on the battery will be a small rubber covered opening )that has a fuse behind it. If the fuse is blown replace it with the EXACT size (that is the exact amp. size). Good luck.
