Disabling PAS on BBHSD
    Hi, new owner of a BBHSD-powered Luna Lone Wolf ebike here. I'm not thrilled with the PAS and would like to try running the bike via throttle only to see if I like the power delivery better that way. What is the easiest way to disable the PAS without destroying the capability of restoring it if I decide to reenable it? Can I disable it via programming or do I need to physically pull a wire in the controller? Any other shortcuts that might be easier? Thanks.
    Program without PAS. However you can peddle and throttle at the same time which is even better.
      This thread is all about how to program it that way: https://electricbike.com/forum/forum...tting-pas-wire
      Cutting to the chase if you set:
      PAS 0 - I=100%, S= 0%
      PAS designated assist level = 0
      Throttle designated assist level = By Display's Command
      Then in any PAS level except PAS 0 (PAS 0 has no power) the throttle will operate whether pedaling or not limited by the PAS level selected and PAS operation is entirely disabled
