Golden motor - edge issue.
    Hi!
    So I let my friend borrow my bike with a chinese battery and a MP edge and I ofcourse got it back boken.
    When i hit the throttle it just klicks and gives a small push on rhe wheel but nothing more.
    Take a look at the video:
    https://youtu.be/CGbDc8UlpFM
    The other noise is just from a valve inside the rim.
    Hi anonafyo,
    When I see symptoms like yours I think of 2 things. A bad battery connection. Check to see if power is being supplied constantly. Or something shorted. Does the wheel turn with a bit of resistance with ether the power on, or off?
      Originally posted by Tommycat View Post
      Hi anonafyo,
      Hi! i didnt realize you had answer.
      Nothing shorted.
      The wheel has no resistance.
      It's working properly sometimes.
        :-) Welcome back.
        As the LED power gage shows a loss of full battery power...
        An intermittent problem is usually caused by a bad connection, connector, or poor wiring. Please check for these things between your battery output, and your controllers input. Perhaps slightly pulling or moving the parts involved will show where the problem is.
