motor stops after full throttle
    Issue with my ebike. It stops running after reaching certain speed. I thought it was a throttle issue so I bought a new one but it is still the same. The power indicator shows full charge, the motor just stops...after a few minutes, it works again...if i go fast...it stops again...is this a common issue? thanks.
    Hi Marcantony,
    And welcome to the forum!
    A few more particulars would be most helpful. Such as... What power indicator? (location and type) Full charge indication during problem shut down? Battery voltage, age, and specs. Motor specs. Controller specs.
    Regards,
    T.C.
      Hi, welome to the forum. When you say the motor stops, does the bike turn off completely or does the display stay on?
