Luna charger input wire failure
    Why is the wire on yoru charger braking apart? It is less than a few months old. You guys need to use better wire. Is it due to the wire heating up the cover? Thicker wire is needed then.
    Maybe I should get simple flexable 14 awg wire and hope the american made lasts longer. Yes I get to fix it my self but with what? I have to use liquid tape untill I can get to the store.
    Do I have to buy the billion strand silicon covered wire to fix it? I would not know how to conect it to a plug, and it is vertualy imposible to solder that wire. Unless I had a “resistance” soldering machine.
    I think I can get 3 strand 12awg extention cord wire with a nice bright orenge cover, made in USA? Not likely. But maybe 10awg would fit through that plastic plug? Not likely.
    Looks like someone has been pulling your cord...... The jacket should be completely thru the strain relief. Hit up an electrical supply, SJ rubber cord, or better yet SO rubber cord
    which has higher temp rating. 14gauge is fine.
      The wire was getting bent because I carry it with me. not pulling. the hardware does have this wire, but I am thinking that liquid tape is better.
        If you have the skill I'd just cut off the 3 bad inches and remake the internal connection. Could probably get by with a couple wire nuts. Bonus if you add a strain relief to keep it from getting damaged from tight bends again. Or perhaps using an old power tool cord.
          I finally took the thing apart to discover the reason the wire insulation broke; the stress relief bushing squeezes the wire flat and provides a sharp edge; it is a wonder how it lasted as long as it did. I am going to get a better bushing that does not squeeze the wire.
          The scrapes are from me trying to pull the gadget apart without knowing how.
