Battery not working due to short
    Hi Folks, I accidentally connected my battery discharge wires in reverse to the controller power wires. Battery reads 53 volts but does not power the motor, also cannot be charged. Anything I might be able to do? Thank you!
    For your battery I'd go thru the steps in Sebz's excellent thread seen here... https://electricbike.com/forum/forum...ctrical-issues
    Paying particular attention to the jumpstart and hard reset sections Any fuses?
    Unfortunately reversed polarity to a controller typically has bad results. Try Fechter's tips about checking for a bad controller in this thread BEFORE you reconnect your battery. https://endless-sphere.com/forums/vi...short#p1457075 Best of luck...
    Regards,
    T.C.
