Battery port is fickle when charging
    300w charger and Killer Whale battery.
    Only charges if the cable is sitting "just right" in the battery port. Needs to be carefully positioned each time. Often slips out of contact after some time etc.. Seems to be getting worse.
    I believe the issue to be the port on the battery and not the charger. I did a search for a thread with this discussion/solution but didn't find anything. Anyone have any experience with this?
    You may want to change it to xt60, either that or replace the port.
      Maybe I do not understand. I am using XT60 connections in all places where applicable.
      The issue I'm having is where the charger cable plugs into the battery for charging. It's a small round port.
        https://electricbike.com/forum/forum...5701#post35701
        Check out the part where it is relating to burnt out charged port
          Oh I see now. Thanks!
