PAS(28mph) Throttle(17mph)
    I recently bought an unbranded ebike conversion kit, and built it. Im having one issue though. I can use pas and the motor will run up to 28MPH, but when i use the throttle it limits it to 17.5 MPH. Any ideas?
    Is your throttle output at least 4vdc at wide open throttle?
    Regards,
    T.C.
      I figured it out. Ill take this down. Thanks man. I guess the two blue wires that only connected to eachother on the controller were the throttle governer.
      • Tommycat
        Tommycat commented
        No need to remove... appreciate the heads up! Others might find the info on the single wire speed governor helpful. Cheers.
