Battery Charger, Inverter problem
    I have a Model UY180 battery charger 58.8 volt 3.0 amps which I plug into my new Renogy 2000 watt pure sine wave inverter to charge my bike battery when biking/camping off grid. The charger surges (fan speed goes up and down). The AC voltage coming from the inverter is varying from 96 to 120 volts. I sent the inverter back to Renogy they tested it saying it is "fully functional". Has anyone had a problem with these battery chargers? It works just fine on household AC. Trying to figure out if it is the charger or the inverter. This is driving me nuts!
    I have seen chargers have problems with inverters before, not specific to the charger or inverter you mentioned but it can happen. I would assume due to it possibly not being a true sine wave.
      Thanks for your reply. I can't comment on whether it is a true sine wave inverter only take the manufacturer's word on that. I just purchased a second pure sine wave inverter, different manufacturer and different wattage. Same result from the new inverter. This inverter has a display that indicates a 'short circuit'. So next step, buy a new battery charger and see where that takes me!
        You are probably better off just buying something to step up the DC voltage rather than going DC>AC>DC. Try this https://www.amazon.com/dp/B01HCL7LEW/
          Thanks for the suggestion!! I didn't know there was such a piece of technology! I have a solar panel system at present to charge my camper battery complete with a charge controller. It is a Renogy 100 watt 12 volt suitcase style system with a 20 amp charge controller. https://www.renogy.com/100-watt-ecli...olar-suitcase/ I believe it has up to a 6 amp output. Any suggestions how I would hook up the charge controller that you suggested to this or to my 12 volt camper battery? I'm treading on the edge of my knowledge base here. I greatly appreciate your help.
            You might try asking for tips from the folks in this thread https://electricbike.com/forum/forum...-the-same-time
            They are more familiar with this product than I am. It can be a little tricky to use but it does come with a printed manual for what it's worth.
