Gear sensor
    Gear sensor
    This is a friends gear sensor on a conversion, it is just installed on a bare length of cable. I don`t see how this will work?
    I tend to agree with you as the sensor housing must stay static or stationary in relationship to the cable that passes thru it. Perhaps if he intends to secure it to the down tube. But dirt and water egress may be of a concern.
    Regards,
    T.C.
      Duct taping it to the frame may be ?
        Inside look at the gear sensor assembly... cable turns a wheel that fires the electronics to pause the power to the motor for a moment.
        See the rest and some good tips HERE.
          Need to have the outer cable in each end secured to stop it moving along, then the cable will move inside the sensor and work. The way you have it there you might as well throw it awyay
