Ludicrous 3 problem
    Ludicrous 3 problem
    I have a 2017 Ludicrous 3. I changed the front sprocket from 42 teeth to 46 teeth recently. I added two shims to improve the chain line. When I’m in top gear it seems like the chain wants to jump. It did this before the front sprocket change also. If I drop two gears it doesn’t do it. It only happens when above 21-22 mph. Any ideas?
    Thanks in Advance
    Alan in t Amargosa Desert
    Sorry, I meant to write Crusher 3. My Bad!
    Alan in the Amargosa Desert
      Hi Alan, and welcome to the forum..
      Have you checked for chain stretch? There is a little tool available to do this.
      BBSHD/BBS02B builds: IGH 1 2 3 4 5 Derailleur 1
        I’ve checked the chain stretch several times and it’s well within the limits. I’m wondering if the derailleur might be out of adjustment.
        Thanks
          You could always rework the rear cassette for better chainline.
            When you say rework the rear cassette. What do you mean?
            TIA
              https://electricbike.com/forum/forum...-drive-systems
                Thanks for the link. I’ll hopefully learn something helpful!
