Can this be fixed? 6061 T6 aluminum
    was doing some winter maintenance on salsa rangefinder equipped with a CYC x1 stealth. found the chainstay on the drive side is cracked on the "chainstay side" of the weld at the BB. the crack runs across top and bottom and down the outside. the inside of the chainstay appears to be okay but assume it has been stressed. it is 6061 T6 aluminum.
    can this be repaired? can any welder do it? i am in the baltimore area. open to suggestions Click image for larger version
    Have a friend whose acoustic bike did something similar - he decided it was finally time to get a new bike...
    • DJRC
      DJRC commented
      Bought a PK Ripper frame as a 14 year old kid happy as could be from a person that sold me the frame from out of a dark garage at night time. Rode the hell out of it for months until one day I noticed it had been welded in just about that same exact spot right there on this pic of the red bike. My home town had a bmx park and I would jump with that bike day after day for months on end and never had a problem with the weld nor it cracking anywhere around the weld. This is my first post. Just joined tonight. What drew me to this is that just yesterday I purchased a 2005 Marin Vision Pro in what appeared to be mint condition for $360. (Retailed for $3600 plus). Was adjusting the derailers and noticed a crack under the frame on one of the back legs that attaches to the rear wheel. I was super bummed out. Such a pretty bike but to discover a hairline crack was just a total downer. I did some googling and read post after post telling others that once their aluminum frame cracks it is never good again and to just junk it. But then I came across one in which they did a repair by welding the crack. I did further digging and found an aluminum frame repaired by applying carbon fiber with bonding over it. I think back to that PK Ripper that I would literally ride a half pipe on and am going to go for an aluminum weld repair and hope for the best. For those that have cracks I had a bike cracked in just about the identical spot as this red bike and it never failed once welded so some should consider a weld job before tossing the frame as I am about to do with this recently purchased Marin Vision Pro.
    went to the local franchise shop and they were pretty much in agreement with AZ guy. That is if you can get them to look at you much less answer a question. I think i have been labeled as a "known time waster" since i ask questions and don't spend $5k a month on franchised products. so sad (no LBS anymore).
    Looks like i should go steel. Got my eye on an out of stock surley ecr 29er from bikeparts.com. i think that is what i am looking for after building and riding now for 2 years or so, i am kinda learning what i don't want.
    doesn't mean i won't attempt to have a repair made.
      Personally I think steel is the way to go for an E bike. E bikes are already fairly heavy so the weight gain isn't a big deal since we have the motors to make up for it. You also gain a little more comfort and if you have a failure they are usually pretty slow and give plenty of warning compared to other materials that tend to fail suddenly.
        FWIW my buddy's bike was sorely in need of some upgrades... had a decent derailleur but the shifters were crap *and* completely shot and not matched to the cassette so kept on him to replace shifters and cassette but he was just being too cheap to do a $50 upgrade... pretty wild riding behind him and watching the wheel move back and forth... took a quick look and tried to move the wheel around but it felt solid so we finished the ride but at the end I told him something was definitely not right and he brought it by my shop and we put it up on the stand... first just spun the wheel, it looked fine of course, tried flexing it but still seemsed solid... then really grabbed it and flexed hard... then busted out laughing - maybe not the nicest thing to do but when the source turned out to be so dramatic and obvious once I saw it it was pretty funny... I don't know how long he'd been riding it that way but the gap was large enough it clearly had been flexed a bit
        The crack convinced it was time to finally retire it... guided him to purchase an ok low-end bike and it took some convincing to get him to spend an extra $90 to get disk brakes (cable pull) and something more than a 7-speed freewheel (hello, the 70's are calling!!)
        Anyway he's sooooo much happier now... rides a lot more... actually uses the gears now too and turns a decent pedal rpm... before he just put it in a high gear 'cus it shifted so poorly (even after a tune) and pedal slow.... only shift if he got on something steep and so often just push the bike up hills....
          Some brands like Trek say they have a lifetime frame warranty.
          • 73Eldo
            73Eldo commented
            Salsa is 3 years on aluminum frames so depends on how old it is, I'm thinking that's a fairly new model 2019 maybe? Then it depends on your dealer and relationship with the dealer. The Q brands are very loyal to the dealers so it would be up to your dealer to 'go to bat' for you.
          I am the second owner of the bike, but I have the original invoice. Don't have a lot of experience with vendors but am finding they do not want to work with you w/out an invoice or if not the original owner. also, aren't all warranties voided with the electric motor.
          That being said, it doesn't hurt to try. It is a 2020 and I suppose I don't have to let on that it was motorized. I am not a good fibber.
          thanks for the advice!
            Aww pooo, warranty only applies to original purchaser of the bike.
            • Retrorockit
              Retrorockit commented
              Considering how heavy this Trek Navigator based frame is, (and me too) I don't think I could break this if I tried.
              I recall a few years ago a guy contacted his bike manufacturer (I don't recall which but it was a major one) about just getting information on his bike for doing a conversion and they refused to continue to talk to him once he mentioned electric conversion... if they refuse to even talk to someone once they bring up electric conversion I'm going to bet they aren't going to make an exception for warranty LOL
              I get it... we have a litigious society and even a passive discussion let alone warranty effort regarding electric conversion would likely imply condonation from a legal perspective, even if only passive, and as such open them up to liability, and if something entirely out of their purview, caused damage or injury... well let's just say it's easy to see how there's pretty much no upside in it for the manufacturer, and even more so if they also sell electric bikes...
            • ncmired
              ncmired commented
              To the OP - Salsa framesets come around on eBay quite a bit, which is where I found my NOS Marrakesh frameset.
              The only pedallable bicycle DIY non-integrated motor frameset manufacturer I've come across that would honor an added-on motorized frame failure is Jones, and probably only for their special motorable frames (https://www.jonesmotorbikes.com/). But even then they have a "only stock," no high-powered motors disclaimer.
            well I have already traveled to pittsburg, picked up a large krampus frame (color "snot nose curry) and swapped most parts from the Salsa. sad to say I put the cyc on it because of the mods described for the bbshd was more than I want to do (and both my bbs's are already on something else) even the bbs02 looked like a tight fit.
            on the otherhand, i have just found a welder that is willing to attempt a repair on the Salsa. Eddy's Welding who happens to be right next to the Daniel's Dam near Ellicott city, a place I pass on a ride down the Patapsco thru trail. they even had a Google review from a customer who was pleased with his frame repair.
              Rodney, I've read comments in the bike frame community stating if you weld repair a heat-treated aluminum frame, it'll just crack again. Hearsay, depends on where, depends on if reinforced? What's your take or impression?
              My e-bike build details are now over there.​
              • Retrorockit
                I can see that being an issue. The heat treatment will be removed where the metal is melted for the weld. This can cause a tress riser there. Also the metal contracts as it cools locking in some stress.. Hardened metal isn't as flexible as normal untempered material. In steel it often breaks right next to the weld. I guess you take your chances, or you just throw the frame away. The stress can be relieved by heating the area until it gets soft, but again the heat treatment is destroyed by this. This is one of the reasons I suggest basic mid range donor MTBs. The weight saving benefit of high end materials just isn't worth it on a high powered Ebikes.
              My take is, it's probably not the wisest choice to make a weld on a weld. I quess maybe they would grind and fill? I agree it would always be a weak spot but maybe I can return it to "pedal bike" status. However I am really cheap and hate to throw anything away, figure everything can be repurposed into something.
              • Retrorockit
                Start cheap, stay cheap. Keep it cheap.
                I would say weld it and if it doesn't break again you're golden. If it does toss it then. No down side really since it's junk right now.
              so the general consensus seems to be "it's pointless but do what you want". thanks for your input and agree the $120 or so could be better spent elsewhere.
              • lectrik al
                lectrik al commented
                Looks like you ride her hard and put her away wet. I'd say ya probably put at least 50 mi on the crack, and It was still going till ya noticed it, so I think you should find that local inexpensive welder to zap that in a couple small sessions and don't even worry about overheating anything else. A good garage type old timer would weld for 20 sec. putz around with sumthin else awhile, hit it with another zap, and let it cool and repeat till fixed. Another 20-50 bucks and there's many more rides left in that pony.
                For me - I look at breaks like this as nature's way of telling me it's time to move on and know that odds are I'll be happier in the end instead of the bad juju of the time and aggravation of this kind of salvage...
                I recently had a situation where I had to make this kind of decision... had a Honda Accord for many years, very dependable nice car but at 165Kmi was in need of a couple of thousand dollars of work - but doing that work would likely buy another 100Kmi... then I got rear ended hard... trunk would still close but rattled... mmkay, gal that hit me had insurance and they totaled the car and paid me out ($4500) but let me buy it back on a salvage title for $300... cool... then someone steals my catalytic converter... good news is they left the flanges so bolting one in would be ~$500... problem is they yanked the O2 sensor wires... so I decided to see if I could get at the wires easily and if I could, would bolt in a converter and do the other couple thousand dollars with the money from the payout... but after discovering getting at those wires was *very* involved and so.... time to move on... serendipity struck and a friend who's mother aged out of driving needed to get rid of mother's vehicle and I got it for a song, likely less than what the honda would have cost to bring into decent condition and I have a younger vehicle in much better overall shape (literally only driven on weekends by an old lady)...without all the grief and negativity the Honda was becoming... and in the end I'm in a much happier space...
                I get it - I don't have an endless coin tree in my back yard and will fix stuff when it makes sense, but for me, this wouldn't be one of them
                We all different
                YMMV
              • Retrorockit
                Another technique is to find the ends of the crack, and drill a small hole there to keep it from spreading further. Then weld the hole shut.
                Download Citation | Stop drilling procedure for fatigue life improvement | This paper investigated how the stop drilling procedure improved the crack initiation life and the total fatigue life in specimens of 6061-T651... | Find, read and cite all the research you need on ResearchGate
              Welding aluminium is tricky. Steel might work. Im from the steel and chromoly era frames and one thing to remember is to find the drain holes in a steel frame and unplug them to prevent the rusting.
                Well I think this frame is now junk. Not only is the chainstay cracked at the BB weld, but I have also noticed the right seat stay (??? real name) is bent as well.
                I have since transferred my X1 stealth and components to a Surly Krampus (all steel) and luvin the hell out of it! Even full rigid is pretty sweet to my tired Ole Ass (right now anyways)
                  I like steel. I get why high performance especially road related non E stuff got away from it but for a vast number of people aluminum just cost more and gives a harsher ride. Most people a couple of watts of efficiency loss due to weight and flex isn't going to make any difference so why not take the comfort? Especially for E bikes where we tend to really add a lot of weight.
